MultiRX range
ki4tga
MultiRX range
Post by ki4tga »
How can i increase the range of the MultiRX so i can monitor vfoA and vfoB at the same time?
Re: MultiRX range
Could you please describe an example of a configuration that doesn't work for you?
DO2ZA Erwin
Re: MultiRX range
Post by DO2ZA Erwin »
simply use the Zoom
Edit: Of course, only in the same Band and a high Samplerate 384000 or moore
73 Erwin
ki4tga
Re: MultiRX range
Post by ki4tga »
w-u-2-o wrote:Could you please describe an example of a configuration that doesn't work for you?
Right Here is on 10m and it wont let me activate it at that span. thats at a 768000 sample rate
Screenshot 2023-08-15 163955.png (753.62 KiB) Viewed 4206 times
ki4tga
Re: MultiRX range
Post by ki4tga »
i can increase the sample rate to 1536000 and can so may just do it that way. ty
Re: MultiRX range
ki4tga wrote:Right Here is on 10m and it wont let me activate it at that span. thats at a 768000 sample rate
Of course it won't. 29224 KHz - 28100 KHz is 1124 KHz. That is well outside your chosen sample rate, i.e. IF bandwidth, of 768 KHz.
You will be able to do this if you change your sample rate (IF bandwidth) to 1536 KHz.
ki4tga
Re: MultiRX range
Post by ki4tga »
yes on my next post i did so. ty for the quick response. i was unaware that sample rate=bandwidth. ty
