Windows 11 22H2 and Network Throttling hack
ea3aqr
Post by ea3aqr »
After updating two PCs to the latest Windows 11 ver. 22H2 my Network Throttling hacks were reverted back to its defaults on both machines.
So please, after updating your computers to W11 22H2, check the registry and confirm your settings.
Jordi
Re: Windows 11 22H2 and Network Throttling hack
I'm on W11 22H2 Insider Preview Build 22623.730 and my setting hasn't changed:
Jordi--does the built in settings feature for this in Thetis no longer work for you?
ea3aqr
Post by ea3aqr »
w-u-2-o wrote:Jordi--does the built in settings feature for this in Thetis no longer work for you?
I don't know, I don't run Thetis in administrative mode.
I always check the hack after every "big" Windows update.
ea3aqr
Post by ea3aqr »
K1LSB wrote:I'm on W11 22H2 Insider Preview Build 22623.730 and my setting hasn't changed:
My settings changed on 2 computers.
I'm using a spanish OS, who knows if that is the reason:
Edición Windows 11 Enterprise
Versión 22H2
Instalado el ‎03/‎10/‎2022
Versión del sistema operativo 22621.608
Experiencia Windows Feature Experience Pack 1000.22634.1000.0
AndrewK
Post by AndrewK »
Windows update reset the throttling index here as well, the builtin setting feature took care off it.
The other thing I notice is the System CPU usage display in Thetis is incorrect now, flickering between 0 to 1%.
In resmon system is using 6%, also according to resmon Thetis is now using 0.3% prior to update was 3%.
Andrew
VK4DNA
ea3aqr
Post by ea3aqr »
AndrewK wrote:Windows update reset the throttling index here as well, the builtin setting feature took care off it.
Andrew
VK4DNA
Me too, 0-2% in Thetis, but 6-8% shown in task manager (total CPU use).
